Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 Vragen Bekijk alle
After replacing touchscreen, horizontal black lines on lower LCD?
My daughter's 3DS touchscreen was not working correctly, so I bought a replacement digitizer and replaced it. Everything seemed to work well, and the touchscreen is now fully functional, but I believe I must have put something back together incorrectly as now there are a few black lines across the lower screen. I'm happy to take it apart again, but if anyone has suggestions for which connection would be the issue, and what might cause this, I'd really appreciate the help !
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
if you see horizontal lines or lines of blocks that means you didnt fully make the connection on the your connector. The ribbon cable is not fully seated correctly on the connector to the motherboard
Was dit antwoord nuttig?
Score 1
1 Opmerking:
+ 99% chance your answer is correct. The cable could have been damaged being the other 1%
door
Voeg je antwoord toe
Duncan Mackenzie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 654
