Ga door naar hoofdinhoud
This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
top dc charging port broken in gamepad
Hello...I am trying to find a replacement part for my wii u gamepad...the top charger was inserted the wrong way and has snapped the charging pins in the gamepad. I can still charge it from the charger docking station. but cant use the gamepad while charging(annoying)...anyway I was just hoping you could point me in the direction of some where I could purchase the part I am looking for ..Thank You..
Is dit een goede vraag?
Score 10
1 Opmerking
can it be fix or replaced i had this console for 11 years a
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hey mate, its not to hard to find them (unlike a lot of console components) and is easy to replace. you can pick them up off ebay fairly cheep;
http://www.ebay.com/itm/USA-SELLER-New-W...
That was just the first one i clicked on so you might get one cheaper.
Hope this helps you out.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thank You for your answer unfortunately this one is for the bottom of the gamepad I need the little two pin socket at the top of the gamepad
door
part: http://ebay.to/1l2TLu6
guide: https://www.youtube.com/watch?v=c6_YRoLe...
Score 2
@steve, did you find a solution? My kid pulled the corde and broke the pins in the top charging port. I only see the bottom one on eBay...
Should I be looking at a refurbished gamepad for parts?
Do you have any guides too for the replacement?
Thanks!
Voeg je antwoord toe
steve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 11,788
