Ga door naar hoofdinhoud
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 Vragen Bekijk alle
Vraag afgerond
Why my Phone is rebooting on sligh bump?
Hello,
My galaxy note 2 is rebooting on sligh bump, i already opened it to see if its the wires // Connectors, and everything seems fine.
The battery isnt loose, and i forced to put a piece of paper just in case, it change ntg...
Where should i look at now ?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Was there any type of incident that could have precipitated this issue, such as a drop or a recent repair? A slight bump causing it to die would instantly make me think, as you have already ruled out, that the battery could be slightly coming out of contact with the prongs. I've seen this a few times when batteries are snug and do not move, but where the frame may be a bit twisted or the battery door not secure.
What actually happens after a slight bump? Does the phone reboot, power off and you have to power it back on, or something else?
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I have the same problem. I dropped my phone several times with no need to repair, but with a slight bump, the phone restarts on its on. Would love to know how to fix the issue
door
Yeah i dropped.and cracked the screen (a fall from a table on a corner of the phone), i made it repair and i replaced myself the jack piece and the power button some weeks after the screen repair.
After the bump the phone reboot by itself. I dont have to turn it back by myself
The back of the phone dont move.
The battery "pins" put a pressure on the contacts so i guess even if there is a bump, it shoudlnt move. But if you have an idea of how i should proceed to verify its from the battery, i am interested.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,244
