Ga door naar hoofdinhoud
Apple released the MacBook Pro 15" Unibody, the second generation of the MacBook Pro, in October 2008 with a new aluminum upper case machined from a single aluminum block.
3092 Vragen Bekijk alle
Trackpad cursor not moving
I'm working on a macbook pro, and I can move the black cursor when I have a usb mouse plugged in, the trackpad won't respond when I disconnect it, but when I try to click, that works. What could be the issue?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There could be liquid or other physical damage to a part of the trackpad cable or connector. Since there's been a couple of iterations of the track pad without a more specific ID (yours covers 7 devices over 3 years) I can't be more specific.
If this answer is acceptable please remember to return and mark it accepted.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
If their was liquid damage wouldn't the clicker not work? I replaced the trackpad cable and the trackpad itelf, and same problem, I can't move the cursor, but it can click if I use a usb mouse to move the cursor
door
I do not know the schematics of the cable but not all the cable wires run "the clicker" that's why it could be a bad cable, or a cable that is not in far enough or may be cocked to one side. Also one side of the connector could be damaged. in a different matter a user had a wireless card that he removed and could not get to work. After trying a different card he looked and found a bent pin on the card slot. He managed to correct the pin without breaking it off and the problem was solved.
door
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 5,276
