Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Vragen Bekijk alle
Vraag afgerond
What is this doohicky with pins next to the RAM slots called?
So there is a black doohicky between the battery and the RAM slots. You can see it circled in this picture of the 2012 MBP 15" teardown. It has two pins coming out of it there are springy, which I think are intended to prevent the bottom cover from getting too close to the electronics.
One of the pins isn't springy anymore and is broken in my MBP. I would like to replace the part, but have a hard time figuring out what it's called and what terms to search for. Anyone have any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Its has two functions: A spacer to protect logic board from being crushed by the bottom cover and a grounding strap that ties the upper case to the lower case to help control EMI noise.
As to getting a replacement, I think you'll have a hard time finding it. I've already stripped them out of my two junkers.
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 110
