Ga door naar hoofdinhoud
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
My Dualshock 3 Controllers mini usb broken and not charging?
My controllers mini usb port has broken and it is not charging ....How do i replace the port ps. i konw how to solder etc and i have an woring port i can replace it with
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I've never replaced the USB on a dual shock before but I have repalced many USB connectors on phones. Shouldn't be any different. Your soldering knowlage should carry you to success.
Before you do any work on it make sure you do your research as well as just looking at how the board and usb are soldered. Disassemble the remote and just take a look at it. Take pictures of the current USB and board for reference. Pre heat the area and make sure you have plenty of flux to keep the heat flowing to the right place.
Good luck on your repair.
Was dit antwoord nuttig?
Score 3
Did you figure out how to do this, because I would like to know how with step by step instructions like you did on the dualshock4 controller.
if you know please email me a pta_red_robin@hotmail.com
Voeg je antwoord toe
rmeiring zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 4,187
