Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Stuck in recovery mode loop after screen replacement.
Hello! After repairing an iPhone 5s, the phone booted into recovery mode. I connected the device to iTunes, and tried to both update to 8.1.2 (no luck, kicks device back to "Update or Restore?" option) and restore (again, no dice, simply returns to update or restore). I am provided no error code by iTunes, it extracts the software, enters restore mode for several minutes and then exits back to "The software on 'iPhone' needs to be restored to factory settings or updated."
Anyone experience this? I was very careful in the repair, one I have done probably 200+ times without this error.
Is dit een goede vraag?
Score 1
2 opmerkingen:
UPDATE: I was able to force the phone out of the loop somehow. I uninstalled and re-installed iTunes, and when through the restore process again, and this time it stuck. I guess it was an iTunes issue :(.
Thank you to those who tried to aid in this!
door
thanks, I had the same issue and was able to fix it as well. thanks for the update.
door
Voeg een opmerking toe
2 Antwoorden
Hello there you have damaged something during the repair most likely motherboard.. Did you disconnect battery during the process?
Was dit antwoord nuttig?
1 Opmerking:
I did not disconnect the battery. I suppose it is possible the board became damaged, though I am careful to use only plastic tools on the inside of the phone.
Any recommendations on forcing the phone out of the recovery loop?
door
Have you tried holding power + home to get it out of recovery mode
1 Opmerking:
I have tried this method several times; no luck unfortunately.
door
Voeg je antwoord toe
Michael Gilliam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,529
