Ga door naar hoofdinhoud
Kledingstukken die je warm houden op frisse dagen en droog op natte dagen. De moeilijkheidsgraad van de reparatie varieert van het eenvoudig patchen van scheuren tot meer gecompliceerde reparaties.
20 Vragen Bekijk alle
Zipper comes apart when fully zipped
The zipper on my coat, when full zipped up comes apart in the middle of the coat. So the top is still zipped and the bottom is still fully seated together. Is there anyway to fix this without replacing the zipper? It's really annoying!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sarah,
It might be that the zipper pull has "opened up". This can happen by forcing the zipper or just from use. It last happened to my 15 year old down vest. Give this a try. First make sure the zipper and pull are not damaged. If they appear to be OK take a needle nose pliers and carefully squeeze the fat (lead) end of zipper pull to slightly lessen the gap the zipper and zipper tape need to go through.
It works for me if everything else looks good.
Good Luck
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks Chuck~! I got a super cute sweater jacket that was a steal from a thrift store. $1 versus $155....but then realized that the zipper did not work. Will pick up a pair of needle nose pliars & give it a try!
door
Voeg je antwoord toe
Sarah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 7,303
