Ga door naar hoofdinhoud
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
How to upgrade the HDD with a 7 mm SSD drive?
I have an Inspiron 1545 with its original HDD drive and I want to replace it by a new SSD unit. The main problem is that the original HDD has a height of 9.5 mm and the newest SSD units (like the Samsung 840 Evo) has a height of 7 mm. I know for several post in the web that the solution is to buy and attach an "SSD Spacer" to the disk. This piece of plastic ensures that the SSD will be recognized by the Laptop BIOS, but the problem is there is not a step by step guide that shows how to do it in the right way.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Nothing magical here just a mechanical spacer to lift the drive up.
This spacer goes under the drive to lift it up so the SATA cable location is at the same level as the 9.5mm drive would be. If is not done the stress on the cable/connector mating can cause a bad connection.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Miguel Angel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 2,025
