Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
S5 stuck on charging battery icon
I did a Galaxy S5 glass/lcd repair and now the device won't turn on. When the S5 is plugged into a charger the charging battery icon appears and fills up with the green stuff, but the phone will not turn on. I tried to get to the boot menu by holding down the power button and down volume button, but I still get nothing. I also tried to get to the custom download page by holding down the volume button and home button then plugging into a usb laptop outlet and I still get nothing. I have lots of experience fixing phones and this is not my first S5 repair. I have done plenty and have never run into this problem. Nothing looks damaged. Has any other techs out there run into this problem and know a fix it?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Happened to me the same problem replacing the lcd. Any comments could help to resolve the problem.
Was dit antwoord nuttig?
1 Opmerking:
same thing happened to me
door
Try switching the power button connector. It is located under the long piece on the back of the S5 in the upper left corner.
1 Opmerking:
press the board into the frame around the power button. The contacts are loose.
door
Voeg je antwoord toe
DK123 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 2,539
