Ga door naar hoofdinhoud
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Vragen Bekijk alle
R4 card works in my sons DSI but not my Daughters?
I have updated my r4 card( v1.4.4) to r4i v1.80b which works perfectly on my daughters dsi, However I purchased a 'used' dsi for my son and the same card doesn't work n his? it come up with a black screen saying the following,
AN ERROR HAS OCCURED.
PRESS AND HOLD THE POWER BUTTON TO TURN THE SYSTEM OFF. PLEASE REFER TO THE NINTENDO DSI OPERATIONS MANUAL FOR DETAILS.
Any info would be much appreciated.
Regards,
Andy.
Is dit een goede vraag?
Score 2
1 Opmerking
Because the 'used' dsi console firmware is higher than your r4i card firmware, so the r4i card didnot work. You need to upgrade your r4i card and here is the tutorial:https://www.digitopz.com/r4i-gold-3ds-tu...
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Because the used' dsi console fimrware version is higher then your r4i card firmware. So it didnot work. You need to upgrade your r4 card and here is the tutorial: http://www.digitopz.com/r4i-gold-3ds-tut...
Was dit antwoord nuttig?
Score 1
This is so old that I doubt you’ll respond or still have this problem, but now an R4 card is useless. A new DSI exploit called memory pit allows you to install TwilightMeNU++ and other hacks via just an SD card.
See here:
https://gbatemp.net/threads/memory-pit-a...
Score 1
Voeg je antwoord toe
andy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,188
