Ga door naar hoofdinhoud
Repair and disassembly guides for Lexmark printers.
19 Vragen Bekijk alle
Lexmark Genesis s816 has slowed to a crawl
After several years of very successful use, my multifunctional device slowed to a snails pace when printing anything. It takes over 4 minutes, for example, to print a test page. What could be the problem?
The device is running the latest firmware.
Thanks, Anna
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
HOW TO FIX LEXMARK GENESIS SLOW PRINT
I have also had a lot of problems with slow printing of and on. Never had time to look into the problem until now.
- First try closing network/wifi connection via the display on the printer.
- Power off the printer.
- Close any wifi or other network connections you have been using for the printer. Like a router, mobile device etc.
- Use the USB cable ONLY for printer connection.
Now power the printer on again.
- Make sure the wifi-icon on the display HAS the yellow triangle warning. If not start over again from top.
- Test printing again.
If the problem persists update drivers etc.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
belkjab zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 8
Altijd: 182
