Ga door naar hoofdinhoud
De Visual Land Prestige Pro 7D met modelnummer ME-7D-8GB werd uitgebracht in september 2013 en is een betaalbare en stevige tablet die is ontworpen voor kinderen.
Why won't my device charge?
I tried charging my device using the supplied cable which is in good condition and it didn't work.
The device is out of power and I can't get it to turn on. Up until now my device would charge but would lose its charge faster and faster.
It showed a low battery icon the first few times I tried to turn it on after it ran out of battery, but now it doesn't do anything.
What should I do?
Is dit een goede vraag?
Score 5
2 opmerkingen
how can you tell when the battery is fully charged.does the battery icon ever supposed to turn green mines stay yellow.
door
Had the same problem with my tablet charge it and boost and it still wouldn't come on . Got a new charger and the same thing what is wrong with this tablet only had it six months.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Your battery may need to be replaced. Follow the Battery Replacement Guide for instructions. The guide can be found here.
Was dit antwoord nuttig?
Score 1
Trash it. Cheap tablet. They supply defective xformers which overheat, short out and blow the Charging circuit inside the tablet. Mine lasted less than two weeks.
Voeg je antwoord toe
Max Hudson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 3,015
