Ga door naar hoofdinhoud
Complete demontage en montage handleidingen voor de meeste iPods, inclusief iPod Original, Mini, Nano en Touch
6220 Vragen Bekijk alle
making a clear lcd screen
Hi, I have been repairing some iPods lately and iPhones, something that is really bugging me is that fact that everytime I finish the job and put everything back together there is a smudge of some sought or a tiny bit of dust or hair. Now I have been using a lint cloth. My question is what spray can I use and what cloth, so the iPod looks as it did before? thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I always use a microfibre cloth - it's a special one for glass/windows
to get rid of the dust i use canned air (computer or electronic stores should have it)
andrew is right, but sometims - the dust is already in the device and when you open it, the dust spreads all over the lcd/screen
avoid touching the screen/lcd with your fingers - there are special "electronic gloves" to avoid this problem
Was dit antwoord nuttig?
Score 2
1 Opmerking:
+ Didn't think to consider about dust already under there, good advice.
door
You need to make sure you are working in a clean environment, that is the easiest fix. There is no real special trick to it, just make sure hair and dust don't get under there in the first place.
Hope this helps!
Voeg je antwoord toe
david zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 772
