Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Battery won't budge - suggestions?
I'm trying to replace the battery on an iPod 5G video (30GB). I got the case open (after some drama - I think the plastic got brittle over the last eight years...) but the battery won't budge. The directions say that the battery will come loose with some prying, but mine seems fused to the case. I'm afraid I'm starting to bend the case itself, and I'm worried I'll damage the ribbon cable that goes under the battery.
A friend suggested using a heat gun to melt the glue, but using a heat gun on a battery seems like a bad idea.
Ideas?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
ellard, the battery is fastened with some double sided tape. You will have to pry it out. Yes, it may take considerable force, but there is no other way to do it. you may tear the hold switch/ audio jack flex, but you can replace this fairly easy as well.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
After your suggestion, I went back and got a bigger lever, and indeed the battery did come out. I was able to preserve the hold switch cable by gently teasing it apart from the mass of glue.
I'm letting the whole thing charge completely before testing it out, but it rebooted when I attached the charger and is flashing the charging icon, so I am optimistic.
Thanks!
door
Good job. Sometimes it just needs an extra bit of oomph!
door
Voeg je antwoord toe
ellard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 166
