Ga door naar hoofdinhoud
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Vragen Bekijk alle
Booting to a white screen?
Hello, I have two MacBook Pro 13" 2009 that are booting to a white screen.
Both of the computers Boot, Fan Spins, I can hear the chime, and then it goes to the dreaded white screen.
One of them works with an external monitor so I have been able to use it in that manner.
The second MBP will not detect my external monitor so it seems I have two computers, both booting to white screen but with two different internal problems.
Any Ideas? Thanks a lot
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Generally if you get no image at all on an external monitor the GPU/VGC is bad.
White screens are sometimes caused by corrupt OS folders. Try booting from a different volume (R boot or Optical/USB/Target volume).
If this answer is acceptable please remember to return and mark it accepted.
Was dit antwoord nuttig?
White screens generally indicate hard drive problems. These machine also have known issues with the hard drive/ IR cables going bad and destroying the hard drives. Use the one that boots to the external monitor and use a firewire cable and Target mode to repair the hard drive or clone it. That failing, try installing the know good drive and cable in the machine that is not working.
Voeg je antwoord toe
Platinum Plus Services zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 327
