Ga door naar hoofdinhoud
De Motorola C261 werd aangekondigd in 2005 en uitgebracht in 2006. Deze telefoon is inmiddels uit de handel genomen. De telefoon die in deze handleiding wordt gerepareerd, is verder geïdentificeerd aan de hand van modelnummer TFC261B.
Why won't my phone turn on?
My phone won't turn on when I try to turn it on. There is no indication of power or activity after using the power button like normal. The problem is consistent and more attempts show no changes to the result. What might be the cause, and what can I do about it?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Here are a few simple ideas that you can use to diagnose your issue:
  • Make sure that your phone has been properly charged.
  • Make sure that you are holding the power button for at least three seconds.
  • Make sure that your charger is working by testing it in different electrical outlets.
  • Check the electrical connections at both the phone and the wall.
These fixes may seem ridiculous but are often overlooked. If none of these options get your phone to power up your battery may need replacing. See the troubleshooting page for this device to learn how to replace the battery.
Was dit antwoord nuttig?
Voeg je antwoord toe
Alexander L zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 332
