Ga door naar hoofdinhoud
The Toshiba Excite 10 AT300 was released in mid 2012. It boasts a NVIDIA quad-core processor, 10.1 inch Gorilla glass display, and runs on Android 4.0 operating system.
Why is the sound not working in apps?
When I open some apps on my tablet, the sound fluctuates or does not work at all. I have checked the app setting and the sound is turned on. Is this a problem with the software or will I need to replace the speakers?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
First, make sure that you check your tablets overall audio settings to make sure that sound is enabled and the volume isn't completely turned off.
When you try using the physical volume controls, does a volume status show up on the screen? If there is a " / " through the speaker icon then your tablet is stuck in mute. Try using the volume control to move the volume all the way up and then back down to toggle the mute icon.
If you don't mind doing a factory reset that would be your next step, to perform this follow the steps on How to Perform a Factory Reset. Be careful with doing this because it will wipe out all your data.
If this still doesn't work you may need to replace your headphone jack and speakers, the steps for these can be found here: Headphone Jack Replacement and Speaker Replacement.
If none of these solutions fixes the problem you may need to contact Toshiba directly.
Toshiba Excite 10 AT300 Headphone Jack Afbeelding
Handleiding
Toshiba Excite 10 AT300 Headphone Jack Replacement
Moeilijkheid:
Moeilijk
45 minutes - 1 hour
Toshiba Excite 10 AT300 Speakers Afbeelding
Handleiding
Toshiba Excite 10 AT300 Speaker Replacement
Moeilijkheid:
Eenvoudig
15 - 30 minutes
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Theresa Stewart zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,810
