Ga door naar hoofdinhoud
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Vragen Bekijk alle
Adding Bluetooth 4.0 card to Early 2008 MBP
Hi -- not very technical, but have followed guides here to install SSD on an early 2008 non-unibody MBP. Was wondering if it's at all possible to put something like a BCM94331PCIEBT4CAX bluetooth card into this unit, so that I can activate Continuity/Handoff on Yosemite. I doubt it's possible, and the needed connectors are probably not even in this old laptop, but thought I would ask. Thanks!
Any other advice or methods of getting a bluetooth 4.0 card installed internally on the MBP would be greatly appreciated. Thank you.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Review this: Continuity Activation Tool
Was dit antwoord nuttig?
Score 2
This doesn't seem to answer the question at all.
1 Opmerking:
Well it did back in 2014 ;-}
The site has altered things and the info it offered is no longer there.
This series can't support Hand-off Services
door
Voeg je antwoord toe
Hiryu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 1,586
