Ga door naar hoofdinhoud
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
flex cable is off (digitizer)
touch screen doesn't work upside.
I fond out that flex cable of front panel is out of place.
I tried to stick it on panel.
but it doesn't work at all.
Please tell me Is it soldered or to adhere.
English is not good but hope you understand me
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
For this problem soldering is not a good answer, its best to replace the digitizer. But if you still want repaire this with out replacing then you need to connect the cable from the exact place where it came out from and make sure that all the contact from the cable is touching the digitizer then you can use silicon to paste it around the cable.
Try this it might work.
Ashwin
Was dit antwoord nuttig?
1 Opmerking:
Thank you for answering my question.
But I wonder why silicon is used.
And not know how to use it.
door
Voeg je antwoord toe
hegu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 184
