Ga door naar hoofdinhoud
This page contains replacement guides and a troubleshooting section for the Craftsman Scroller Saw Double Insulated 5/8" Stroke-Variable Speed (Model 315.10721). This handsaw was manufactured in 1979 by Sears, Roebuck and Co.
Why is the trigger on the saw sticking?
When I press the trigger to turn on the saw, the button seems to get stuck frequently. What can I do to solve this issue?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Either it's choked with dust/grease/debris or it may be broken inside (lock button or actual micro switch).
You'll have to examine it closely - use some spray cleaner, if that doesn't work take it apart and check the trigger for damage.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Riley Hilliker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 178
