Ga door naar hoofdinhoud
The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
29 Vragen Bekijk alle
How to install 8GB Ram in Asus X551CA?
Hi, im planning to buy 8GB RAM memory for my ASUS X551CA laptop.
How to install the 8GB RAM Memory in X551CA Motherboard ASUS Laptop? and what is the limit of Memory Slots of ASUS X551CA Motherboard? is it 4 or 8 GB only? Thanks
Is dit een goede vraag?
Score 3
5 opmerkingen
We need the full model name like X551CA-XXXX.
door
asus xx51cap
door
email me at denznewgate25@gmail.com form ore information about my laptop :)
door
what about this one x551ca - sx014h
is upgradeable to 8gb
door
Hello
Is it possible to update RAM in Asus X551CA-SX030H?
in specification there is information that can take up to 12GB
Thank you for info
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
4 GB is soldered onto the motherboard. No slot for expansion. So if the ram is bad, get a new motherboard or just throw it away.
Was dit antwoord nuttig?
Score 4
I know this is an old post but online there are different answers to this question. I am adding this in case someone needs the ultimate info:
The asus x551ca-sx024h PCB rev 2.2 doesn't have any additional slot, see the pictures, in the last one you can see that the slot is empty and the RAM is soldered directly in the PCB
Score 2
the RAM limit on your notebook is 8GB so, you can upgrade your RAM, its really simple to change it. if you haven't bought the RAM the check this crucial link http://www.crucial.com/usa/en/compatible...
Score 1
The ram slot is on the bottom of the motherboard. There is no access panel so the motherboard has to be removed and RAM added.
Voeg je antwoord toe
denznewgate25 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 14,127
