Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Vragen Bekijk alle
Vraag afgerond
iPad slow after ios 8.2
Hi,
After uptade to iOS8.2 my iPad 2 became very, very slow and sometimes crashes.
Is there a solution for this problem?
Thank you.
Vivian
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Check the following:
http://www.teachthought.com/uncategorize...
Good Luck!
Was dit antwoord nuttig?
Score 1
Just stumbled across your question. Is this still a problem? Haven't heard of this happening before. Have you tried the obvious things like restarting the iPad and closing the running apps? Is your memory full or close to full? That can slow it down as well. Check at Settings > General > Usage
My problem is when I check at setting>general>usage it says iOS 5.1.1 update.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 733
