Ga door naar hoofdinhoud
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
59 Vragen Bekijk alle
How do I repair a cut headphone cable?
The cable of my Apple EarPods got cut above the mic. I'd usually be able to repair a cable, but because everything inside is so tiny, I can't really tell what's what. Is there a way to repair the cable?
Is dit een goede vraag?
Score 2
2 opmerkingen
So did the volume button get cut off?
door
No, it was cut above the volume button and microphone. There are only two wires inside the cable, they look like they're wound around a small string, I can't see any insulation, just two differently colored wires.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Yes there is 2 different coloured whiers
Twist the one colour to the corresponding colour other whier.
Heat it carefully.
Then apply a few drops of solder to get it properly.
Cover the whire in electric tape.
Do the same for the other.
Tape the hole thing together.
Hope this helps
Truls
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thank you, I'll try that!
door
Did that work???
I tried for Sennheiser Ear phones.. But it didn't...
I have joined Red and Green as one and the other Copper wires as one.
Please let me know if I am doing wrong.
door
My iPhone cables are damaged below mic what should I do ?
door
I Have A Minor Cuts Becoz Of That I Have To Insert My Earphone For 5-6 Time To Enable My Microphone.Becoz My Microphone Doesn’t Start
door
Voeg je antwoord toe
Sophia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 105
Altijd: 16,465
