Ga door naar hoofdinhoud
Identifiable by the model number S7562, the Galaxy S Duos is a dual sim card smartphone made by Samsung.
104 Vragen Bekijk alle
Wifi on my Samsung s duos is not working
When I on the Wifi, it goes into light green mode and does not come into complete green mode[Which is wifi adapter is failing]
Any suggestions on this.
Tried factory re-set but still the same.
Is dit een goede vraag?
Score 95
6 opmerkingen
i hav the same problm,,wt can i do nw,i tried so many times its nt workinngggg
door
mi wifi no funciona se daño solo me funciona con paquetes de datos
y eso no megusta por que es demasiado lento
door
My WiFi connection is on but connecting any network does not connect and shows saved &secured
door
My wifi Didn't even turned on.
door
mobile does not support jiofi hotspot after connecting it show saved and secured but nothing work on it. plz help me why this is happening
door
1 commentaar meer tonen
Voeg een opmerking toe
23 Antwoorden
Het nuttigste antwoord
Dear All,
Wi-Fi Freezing fault may occur due to 10% of Wi-Fi driver related issue and 90% of WiFi hardware fault,
Simply you can use hot air flow to U204 module and check whether it's functioning back to normal
other wise you will have to repalce new U204 Wi-FI + BT module
Here you can find parts for repair
Note : BGA reworking skills required to replace WiFi module
Hope you will be able to fix the fault your self.
Cheers!
Was dit antwoord nuttig?
Score 5
Update (09/05/2016)
Score 3
wifi not torning on way
Score 2
dail*#*#526#*#* on your phone keypad this will show a message driver software sucessfully installed than try to turn on wifi this will turn no easily
Score 1
3 opmerkingen:
It's not working.. can u please suggest me any other solution. .
door
it's not working ...... can u plz give another way to solve this problem ...
door
It is not working and can you please any other way to solve this problem
door
when we on the wifi the siginal ra not displayed on the screen what we should do for that
Score 1
is it your own WiFi signal if it is, is it been set with a password for protection preventing other users connection to your signal?
Update
Usually if it's able to pick up the wi-fi network but does not want's to connect is usually with the secuirity settings. you can try by deleating that as you defalt network and the se-activate it (try to reconnect to it) the default proiblem is usually the security settings.
1 Opmerking:
the same problem occurs on not protected wifi..
door
yes same my problem on my device
sumsung s 7562 wifi not working
Yes me too...its feel so annoyed
all site are open with wifi but not download any app my phone with wifi
Try. *#0011# > Menu key > Select Wifi > Select Power save button Off
Thanks
1 Opmerking:
Tried this but not working
door
samsung s duos wifi not turning on
1 Opmerking:
door
How to connect wifi adapter
you should heating wifi and bluetooth ic and reboiling it or change it
https://www.google.com.eg/imgres?imgurl=...
Wifi on my Samsung s duos is not working.
my samsung 7582 wifi is not waking
why i cannot turn on my wifi in samsung galaxy duos?
I have also same problem....
it no working alwayas on and low green
My s duos i droped it in water then i put it in rice for a few days then i turn it back on everything worked except wifi and it was on low green. Before the water incident it was perfectly fine
This is my problem of my Samsung phone
My samsung duos mobile wifi not start
1 Opmerking:
Big ass big
Hgcgjnncgnngcfhjk
door
My samsung mobile wifi not start
Voeg je antwoord toe
Sandeep zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 77,719
