Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Vragen Bekijk alle
How to fix bent charging port on 3DS XL?
My cat knocked my 3DS XL off of a dresser while it was charging, and the piece inside of the charging port is now bent. The charger can go in if I wiggle it a little bit, and the system is getting a charge, but the more i use the system, the more I notice that the charger easily comes out. It used to firmly stay it. How do I fix this?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Best bet would be replace the charging port, this requires disassembling the device and desoldering the old port, then soldering a new one, it's not as hard as people think as long as you have basic soldering skills. :]
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Could you link me to a guide if possible? I've never opened a 3DS (other than to replace battery.) Also a link to where I can buy a charging port. I can't seem to find one.
door
The charging plug.
http://www.amazon.com/Socket-Connector-C...
And for a guide just search on youtube. :D
door
Heck, you don't even need basic soldering skills. Fixing one of these was the first thing I had ever soldered.
door
Can’t I just bend it back into my place I have the same issue but don’t want to risk breaking the device
Voeg je antwoord toe
Ryan Bonomo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 8,486
