Ga door naar hoofdinhoud
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 Vragen Bekijk alle
AppleTV Remote water damage
Apple TV is great for use in bedroom, until you loose the remote in the sheets and wash it. My remote recently went through a full wash cycle. Found it before putting into the dryer and immediately wiped down and then let rest upside-down and covered in rice for a day. Next day, cleaned the battery area a bit, put in a new battery, and it seemed to work okay for about a day.
Noticed the select button starting to not work (had to really press hard to get any function) but the menu and play buttons worked fine. 48 hours later, the remote is completely dead. Is there a way to fix this? Could not find a teardown or guide for any Apple Remote.
Any help is appreciated, thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Watch this video:
http://youtu.be/bPkKtxTD6J0
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Good but what Vodka are they using?
door
Forget the vodka. Use isopropyl alcohol.
'Our toddler decided the Apple TV remote would make a good fish tank decoration so after fishing the remote out which had been submerged in water for over 10 mins shook all the water out dried off the remote placed in a zip lock bag of rice removed as much air as possible and let sit 24hrs then plugged the remote in to charge! Works as good as new!
buy a fire stick for same price as a new apple remote unless u like the crap programs apple tv actually has.
Voeg je antwoord toe
Tyler Timpe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 98
Altijd: 40,834
