Ga door naar hoofdinhoud
Reparatiehandleidingen voor de MacBook.
Can't put LCD bezel in place...very hard!
Hi,
I'm trying to solve a blinking problem in my MacBook. It seems like inverter cable broken. I opened it to try to fix it before buying a new cable. Now I'm having problems because I'm not able to put the bezel in place anymore because i can't put the tabs in place. Any tips to fit these tabs in?
Thanks in advance...
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Look at the image
http://s1.guide-images.ifixit.net/igi/AJ... All the tabs should be on the frame, not the bezel. They tip in at an angle. It would be ok to glue or tape them in place. If you use tape slit open the slots with a blade before trying to pressfit the bezel.
Support the case completely and start along one side, top or bottom work outward at the same pace. It's ok to squeeze hard on the bezel as long as you are squeezing the edge of the frame and NOT the LCD.
If this answer is acceptable please return and mark it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Eloy Fonseca zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,287
