Asus Laptop D550M Will not boot up.
The power indicator lights are green but the display stays black. Don't hear any beeps that the OS is starting to boot up.
Is dit een goede vraag?
You have to start in safe mode,press f8 while turning it on,and follow what it says.you will be back in no time .
Was dit antwoord nuttig?
I don't get that far ... backscreen has power but nothing comes up ... should I send back for refund? I followed another post and pulled battery and replaced ... did not solve. HELP
I have the same issue. Battery is internal, power lights come on, no sound but screen remains blk. Not able to f8 or anything else for that matter.
CAN ANY ONE HELP?
Remove the hard drive and power on, see if it boots then.
If that doesn't help try interchanging the RAM between slots to see if one of the sticks are bad.
I know this question is 4 years old now, but I'm posting this because I just had this same problem on a customer's computer and I was able to fix it. Hopefully this helps someone else to ended up here after a Google search.
The laptop should now boot up to the BIOS/CMOS Setup screen. Load Default Values and Save & Exit.
You can follow this link to download the latest BIOS firmware file. You will need to extract this file and place the extracted firmware file on a USB flash drive. Insert the USB flash drive into the laptop and boot to BIOS/CMOS Setup. On the Advanced page, enter Start Easy Flash and use this utility to flash the file you placed on your USB drive.
The computer should behave normally now. Hope this helps someone.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,759
I am having the same problem
door stacie4963
