Ga door naar hoofdinhoud
Het eerste van de nieuwe generatie Nokia-toestellen – het eerste met een 1080p-scherm, het eerste met een quad-core Krait-processor
it's it possible to replace the front facing camera
it's it possible to replace the front facing camera?
Is dit een goede vraag?
Score 3
1 Opmerking
I had the same question. The cable became damaged during a screen replacement and I found the replacement camera. Just not sure if its glued on or soldered or some other method. Any tips would be appreciated.
door
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
Use can use these videos.Its really help me a lot for changing my camera.
https://www.youtube.com/watch?v=HQC2lZsB...
https://www.youtube.com/watch?v=qmNUl9Gh...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Neither video is for a 1520. one is for a rear camera and one is for disassembling the 900. Unfortunately neither have a similar front facing camera to the 1520. Did you replace the front camera on a 1520? Thanks for any help you can provide.
door
Use 3m z conductive double sided band. 3M 9703
https://www.tedpella.com/TechNote_html/1...
Score 1
3 opmerkingen:
Also do not forget to heat 70 degrees C. otherwise it will not work.
door
Thank you!
But with this method. all the circuits of the camera you do not risk it to get in touch with each other?
door
The tape is conductive only for Z direction(vertically). Side by side contacts will not be connected. I did it and worked.
door
Yeah, it's possible. Open the phone, find the broken front camera and replace it. But you must have bought the front camera replacement in advance.
3 opmerkingen:
Do you have a guide our video that could show me how before I buy the part?
door
is there a guide or instructions. I can't tell if the front camera is glued down or soldered to the mainboard.
door
I have the same problem I have my camera replacement but not how to do it
door
Hello,
I raise the subject, someone found a solution to replace the front camera?
Voeg je antwoord toe
bob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 2,418
