Ga door naar hoofdinhoud
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Vraag afgerond
Weird bubble effects when replacing lcd and digitiser
Just replaced lcd and digitiser on a mini, when i press on the screen with a little extra force than normal i get like bubbles all over screen, quite hard to describe tbh.
Cant figure it out :(
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Can you send a pic?
Do you get this aswell when you put pressure on the glass?
If so its the glass screen touching the lcd
Was dit antwoord nuttig?
5 opmerkingen:
Hi Con, i only get it when glass is seated onto the lcd after install (fully put together)
door
might be they are touching. i lost the foam when installing, could that be it? thanks
door
Yes I would say that's your problem then
door
anyway i can diy replace ? :(
door
You can buy foam for the edges but not to sure we're to buy
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 908
