Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
Is there a description of what these antenna wires go to?
I am putting my MBP back together and looking at the wires that come from the monitor. They are listed as antenna wires.
Step 29 of this guide shows the wires in question: MacBook Pro 13" Unibody Early 2011 Upper Case Replacement
I guess I can put the shortest of the wires first and proceed to the longest, but is there some other way of knowing what wires should go to what connector, and maybe what they are for?
Thanks in advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Just start with the shortest one first. I don't think it can be put together incorrectly as the lengths dictate that they will only fit correctly.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
stdonato zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 77
