Ga door naar hoofdinhoud
The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
Why does my computer come on then turn off?
When i plug my computer and turn it on, the two green lights in the front come on then turn off. The fans in the computer come on then stop. How do i get my computer to work again ?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
it could be a power supply issue , remove the power supply , and then test it and if it doesnt work, that is the problem... there are special power supply testers for this...
Was dit antwoord nuttig?
Score 4
Open the case, examine the capacitors under the fan cpu fan shroud. If they are not flat and/or showing a reddish/orange color on top, the capacitors blew up. This is not an item that can be fixed in a cost effective manner.
Score 2
Replacing the all 7 of the 2200uF 6.3V capacitors, if any show either swelling or leakage (tops should be flat and shiny, no cracks along the score marks) isn't that expensive or difficult. Parts from DigiKey (493-6909-ND) are less than $7 plus shipping ($3 if you're not in a rush). Takes 30 to 45 minutes to disassemble the machine, unsolder the old caps, remove excess solder, install new, resolder, and reassemble. If you have a decent soldering iron for electronics (not plumbing), good light, and fair eyes, it can be done.
Just did 3 machines yesterday for a customer who uses them on a factory shop floor where their tolerance for environmental abuse makes them perfect. Far cheaper than new machines that aren't as solidly built.
Score 1
Voeg je antwoord toe
Jay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 1,231
