Compatible with iPhone 5 battery?
Hi, iPhone5 battery and iPad mini retina battery have a compatible battery? PIN shape the same? Is it replaceable?
iPad mini is because heavy and say whether such questions why.
Is dit een goede vraag?
The connector and the pin layout is compatible but the system should be able to read from the battery bus to know that the wrong battery is installed.
It should lock out immediately or it can create real safety problems. The ipad draws way much more current than iphone, so if by any chance it seems to be working, it will go overheat and lock out again.
Don't ever try to do it.
Was dit antwoord nuttig?
Thank you, TOM. I understand.
Are you being serious? An iPhone 5 battery in a iPad mini?
The simple answer is no
Thank you, CON. If possible, you want to know more information.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 149
