Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
What is the difference between Glass, touch screen and LCD digitizer
I want to know the difference between Glass, touch screen and LCD digitizer. I have seen Glass with or without connector and dont know whats the difference. Let suppose my iPhone 4s screen is cracked but touch is working what needs to be bought in order to do the repair. What if touch is also not working? Please help me am novice in this field.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
The glass screens you see in ebay with no connections and connections are useless it's almost impossible to remove just the glass from a iPhone without professional equipment.
Jut buy a screen with lcd and glass digitizer it makes the process a !&&* of a lot simpler..
iPhone 4S Screen Replacement
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for clearing my doubts
door
The front panel is the glass which can easily shatter when it's dropped.
Beneath the front glass (enbeded behind it) is the digitizer aka touch screen which is an electrical Inpulse sensor. Both are in one piece.
Then beneath the digitizer is the display screen aka LCD which displays images.
Voeg je antwoord toe
Abhinav Gupta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 13,227
