Ga door naar hoofdinhoud
A1261 - Anyone Experiencing a Partial Keyboard Failure?
My Mac suddenly quit responding to key presses on the lower half of the keyboard. I replaced the keyboard and triple checked the connections. The problem continues with the new keyboard.
I've tried an external keyboard and it works perfectly.
Anyone run into this problem? Any idea how to repair it?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
well , If you replaced the keyboard then It's not a hardware problem , before you do anything try to connect and external USB keyboard and see if everything is fine .If not well it should be some drivers problem
Was dit antwoord nuttig?
1 Opmerking:
Thanks. Yes, I have attached an external USB keyboard and it works perfectly.
door
Hello again , sorry I haven't notice that you mentioned that you used a USB external keyboard at first beginning
I've contacted some people who had similar issue , they claimed that is it a Physical hardware issue , try removing the battery then put it back and press it (Don't force it ) completely to the slot housing ....it has 50% chance of restoring the functionality
Hope I helped , Good luck
1 Opmerking:
Thanks for the advice. I'll check it out over the weekend and hopefully get my laptop back in tip-top shape.
door
Voeg je antwoord toe
portwood zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 198
