Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
How can I find my iPhone passcode?
My iPhone has been disabled for a while now and I want to try to fix it. I already tried what the Apple website says, but nothing works. It said to use iTunes, but I never connected it to a computer in my house after the phone disabled, so that was out of the picture. I decided to try restoring it. It worked, according to iTunes, but the phone is still the same. Finally I tried iCloud and Find My iPhone, but that didn't work either. Is there anyway I can fix this?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Put phone in dfu mode connect phone to computer and open iTunes ..
Now press home and power button togeather at same time for 7 seconds then let go off power and keep pressing home now the phone will be dectected in recovery mode .
Now restore and the passcode will be away and you will start off fresh
Was dit antwoord nuttig?
8 opmerkingen:
what is dfu mode?
door
Do what I instructed you til do that's dfu mode..
Now don't restore from a previous backup cause the code will still be activated you need to setup from new
door
i did that first part but when i let go of power, a few seconds later it restarts, still disabled. itunes does nothing.
door
Ok slide screen so it shows to enter passcode now press and hold the two buttons again now when the screen turns off let go of the power and keep pressing the home button til it comes up in recovery
door
i can't do that because it's disabled. i can only connect to itunes.
door
3 commentaren meer tonen
Any luck?
Voeg je antwoord toe
arjintas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 221
