Ga door naar hoofdinhoud
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Vragen Bekijk alle
Kingston HyperX SSD issue on iMac
Hi,
I successfully installed KingSton HyperX 480 SSD on my 21.5 iMac late 2013, and work perfectly for 3 months.
The one day after updating iTunes and restarting the iMac got flashing question mark folder icon, I tried many ways but iMac won't read SSD at all, even after removing SSD and install it on Dell PC won't read it.
- Now, all my data gone - is it? - Is there any solution for this issue to get back my data?
- Im a fried too much to buy new one and died again! is this possible ?
- Final, Is Kingston HyperX 480 very Compatible with iMac?
Is dit een goede vraag?
Score -1
2 opmerkingen
How did you install this SSD? Did you replace the internal HD or are you using it externally via USB3 or Thunderbolt connection.
door
YES, Replace internal HD by myself.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would talk with Kingston here as your drive should have worked without any problems here.
As to saving your data you will need a second Mac connected via Ethernet or ThunderBolt (USB2 is slow) back to back so your system can be started up in Target mode. Here's how to do to it: OS X Mavericks: Transfer files between two computers using target disk mode,
Then you'll need to try Disk Utility to see if you can repair it. If that fails your options here are limited.
Was dit antwoord nuttig?
Voeg je antwoord toe
ADNAN MARGELANI zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 689
