Ga door naar hoofdinhoud
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
573 Vragen Bekijk alle
How do I fix the broken tip of a microsoft surface pen?
the tip of the surface pen from the microsoft surface pro tablet is accidentally detached from it do you know how to put all the parts back again? Nothing is broken just that the parts came off.I tried searching for many solutions but none you are the only hope left pls help thx
Is dit een goede vraag?
Score 5
4 opmerkingen
What if the tip breaks off (dropped pen) and the rest of the tip is inside - how do I remove the rest of the tip in order to insert another top?
door
I got the same question!
door
Can you pick it out with a needle/pin? (fun tip - those dressing/dress pins with a little ball on one end can give you buckets of extra control here, plus dressing pins tend to be the thinnest things around, needles vary a lot more in thickness/sharpness)
door
What if the black part of the tip falls off and now I can't write with it?
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Just reinsert the nib again in the barrel (Pen) it should work.
Was dit antwoord nuttig?
Score 2
If you're having trouble finding pen parts for SP1, buy the cheapest wacom or s-pen you can find, the tech is the same they're all interchangeable, mine was £5 from china and never looked back since
Score 2
The Black Plastic on a new tip that goes to abou 1mm of the tip is conductive.
If it breaks off the Pen doesn't work properly with the capacitive touch screen sensor.
If you apply conductive ink around the tip, keeping it ~1 mm from the tip, but touching the black plastic, the tip will now work.
Not sure how long this repair will last, but definitely ok for a temporary repair.
PS Conductive ink is available from ebay or most electronic repair outlets.
1 Opmerking:
this is the SP1 which uses wacom, no capacitance here, that may be true for the later n-trig surface pens though, they're an active pen so maybe.
door
Go to a microsoft store or call microsoft support, they'll supply you with free replacement nibs.
Voeg je antwoord toe
Hui Lin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 16,089
