Ga door naar hoofdinhoud
PowerBook won't start with installed battery
Hello
My Powerbook won't start with installed battery.
If the Battery is not installed the powerbook starts normal.
I did all resets i read (PMU, SM*, etc.)
With a new battery it is still the same.
Wich part of the Book is broken?
The power supply is noise *feeep* when plugged in but seams to charge the battery.
PRAM?: With no installed battery it forgets the date after a while with no power cord plugged in
DC-IN Board?: Is that responsible for power management?
or the logic board?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Well you do have a couple of problems here:
First you'll need to replace the PRAM battery if your model has it. Here's the guide to get to it: PRAM Battery & USB Board Replacement. Some of this series had a clock chip which had it's own battery internally on the logic board.
I do think you have a logic board issue with the charging circuit. The DC-In board does not have any of the charging logic on it. This could be a big job to diagnose and repair.
This system is quite old. I think your money & time would be better spent on a newer system. Don't get me wrong here in its day is was one !@#$ of a system! I had the titanium version for quite a few years.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
nudge zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 396
