Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Why does my phone now not charge at all after dock replacement?
My phone originally would only charge when turned off. So I replaced the dock, and headphone jack (for a separate issue). Now it will not charge at all. Any ideas? Did I forget to connect something, or not connect it back properly? I am bumfuzzled.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
The dock connecter plugs into the logic board and is cover by a plate which has 2 screws in it, (see image) aslong as you connected that connector it should charge unless you have a faulty dock connector.
try another replacement dock connector.
hope this helps
Was dit antwoord nuttig?
Voeg je antwoord toe
jema zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 48
