Ga door naar hoofdinhoud
This device is T-Mobile's version of the Samsung Galaxy S II. It was released in October of 2011. It was the first Galaxy to include T-Mobile's new expanded 4G network.
15 Vragen Bekijk alle
Why isn't my phone charging?
I was charging my phone early this morning before my game and before i unplugged it, it shut off and wouldn't turn on. Phone was at about 70% at the time and i still can't get the phone to charge. Please help!
Is dit een goede vraag?
1 Opmerking
You can always get the wireless charger if the USB port isn't working. That's what happened with my phone is the USB port got wet and now it won't charge I have to charge it with the wireless charger now. Or I have to blow dry my phone before I charge it or else it won't work. I hope this helps.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
jesseornelas72, check your charger to make sure that it is working. Try a different cable, and check your port for any debris corrosion and bend/broken pins. If all that checks out replace the battery and reevaluate. If none of that works you could be having issues with the power management IC or the charging coil itself. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Sorry i have ignored the phone brand and model,
This pic is for the Galaxy S 2, and i have marked the Charging dock.
Voeg je antwoord toe
jesseornelas72 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 471
