Ga door naar hoofdinhoud
The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
149 Vragen Bekijk alle
Can I upgrade from 4GB to 8GB RAM memory?
I have a MacBook Air 11" mid 2013 that came with 4GB RAM and 128GB hard drive. I want to upgrade the RAM to 8GB so I can run Vmware more efficiently with windows 8.1 and other software that don't run on the mac-side.
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sadly, no
Apple soldered the RAM to the logic board. You can upgrade the SSD! It's replaceable.
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
Could you replace the entire logic board with one that had 8gb of RAM rather than the original 4gb?
door
Swapping out the logic board with one that has 8 GB of RAM is possible!
But, the cost factor for doing this then becomes the issue. I would recommend locating a used system which is newer as being a better investment.
door
Voeg je antwoord toe
Rich zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 4,767
