Ga door naar hoofdinhoud
No Backlight After Small Spill
Small spill, shortly after, backlight died for good. Apple says it needs a new logic board. Inverter board sounds more likely to me, but I can't even find reference to one in this machine. Is it built into the log board?
Is dit een goede vraag?
1 Opmerking
Based on this, I'd say the inverter board is the most logical place to start.
Does anyone know where I can find a guide/service manual for disassembling the display module once it's off the computer?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
It is built into the display.
Unfortunately, a liquid spill is most likely to damage the logic board. One way to check is to remove the upper case and look for corrosion on the board, especially near the keyboard and speaker area.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
This would show whether it was the cause, but if the only symptom is a dead backlight, you'd think more would be damaged, no?
door
most likely the L board, i agree
door
There definitely isn't a board just for the inverter but you could try replacing the inverter cable itself.
After a liquid spill, it would be natural of Apple to assume the logic board but if the backlight is the only problem, that seems unlikely at best.
I would try replacing the inverter cable, followed by the display. Only then would I try the logic board.
Score 1
Take a look at the post below, which has some more potentially useful info.
no display backlight
Score 1
Voeg je antwoord toe
l008com zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 3,433
