Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
Is there a way to replace the front glass only?
Is there a way to take off the front glass ONLY? With the S4 the front glass was ONLY attached to a cable for the buttons on the bottom. For the S5 there are connectors and copper attached to the glass. Any help would be greatly appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Yes there is a way however I would not recommend it unless you have a hot plate as the s5's LCD is MUCH thinner than the s4's. Glass only is a hard enough repair as it is.... Samsung didn't make it any easier with the s5. If you still want to give it a try here is a video that should help!
https://www.youtube.com/watch?v=rgwiajTa...
Was dit antwoord nuttig?
Voeg je antwoord toe
Sam Giler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 4,106
