Ga door naar hoofdinhoud
The Canon PowerShot A70 is a 3.2 MP point and shoot camera
4 Vragen Bekijk alle
This camera takes blurry pictures.
My camera takes blurry pictures sometimes even though it's been repaired by the folks at Canon (Cmos sensor was replaced? Or that little sensor that sees the object). It needed an update so it was sent in. Now it takes a blurry picture quite often. Any ideas?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
sounds like the auto focus isn't right.
when was the repair ?
why did you send it in for an update (the firmware is downloadable on canon's website)?
i would check the focus settings first, maybe the focus field has a wrong setting!
Was dit antwoord nuttig?
Score 1
Does it focus right when you do macro shots? is there a difference if you are zoomed in and zoomed out?
When you sent it in to repair, it should be under warranty for a short period of time. I urge you to send it in again and report this as I am pretty sure this is a hardware problem and not software.
Recommend contacting Canon again. The CCD sensor may have failed again. Here's more info on the free CCD repair for the A70.
Voeg je antwoord toe
amelnychuk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 3,334
