Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
Restarts every 3 seconds (bootloop)
Hello,
So I tried to repair an iphone 4s with some sort of "bootloop". It restarts every 3 seconds... ( https://www.dropbox.com/s/djk0eclmz4ognz... ).
I changed the Dock connector, I tried a new battery and tried to restore with DFU (error 4005).
Tried Restoring IPSW with redsn0w. No luck..
Could someone help please, I am out of solutions...
Thanks
Michael
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
I had a similar problem with a 4S when I replaced the power/proximity sensor cable. Once I had replaced the cable and reassembled everything, I turned the phone on and it would freeze at the apple logo and sometimes enter a bootloop. I started inspecting the circuit board for damage but couldn't find anything that was apparent, and then I tried unplugging the power cable/proximity sensor. With the cable unplugged, I started the phone by plugging it into a USB cable and it worked perfectly!
So I would try starting the phone in that same manner to test the different components. It is possible that a bad component other than the battery or dock connector can be the problem.
Was dit antwoord nuttig?
1 Opmerking:
Tried to unplug every component, still no change..
The iphone flashes the apple logo (https://www.dropbox.com/s/djk0eclmz4ognz...). Could this be a problem with the Gpu or something?
Thanks
door
I have a samsung galaxy tab 2 10.1 thats doing this same thing. I bought and replaced a new battery, and charging flex cable and still the bootlooping remains. Many have told me that samsung is aware of this issue and it can't be fixed if it wont do a soft or hard reset. Im at a loss. VERY frustrated.
Voeg je antwoord toe
Michael Maeter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 315
