Ga door naar hoofdinhoud
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Vragen Bekijk alle
Nintendo 3DS won't power on?
I just replaced the top LCD screen and after putting it back together it wont turn on. When I press the power button all I get is the 3D comes on then goes off quickly. The motherboard seems to be getting power but just wont turn on. HELP!!!!!
Is dit een goede vraag?
2 opmerkingen
Did you double check your work? Made sure all the cables are properly seated? What made you change the LCD? what happened to your 3DS originally?
door
Yes all cables are fully connected. The top LCD screen had to be replaced because the cable was broken.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Take it to a dark room and turn it on. Watch the screens carefully. See if either of them flash. If the bottom screen flashes then there is probably a problem with the top screen. If the top screen flashes then there is probably a problem with the bottom screen. If no screens flash then there is probably a problem with the speaker ribbons somewhere. This test is not 100% but most of the time it will lead you to the problem.
I hope this helps.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Ok thanks I will try this tonight and let you know.
door
Voeg je antwoord toe
atkinsonkathy37 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 715
