Ga door naar hoofdinhoud
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why won't Alcatel One Touch Fierce Phone charge after teardown?
I did a tear down to change a broken front panel but now
1. the battery will not charge
2. I can hear voices when people call but they can't hear me.
Is dit een goede vraag?
Score 5
4 opmerkingen:
#2 doesn't matter if I can't fix #1
door
did you double check your work to make sure everything is properly connected and seated?
door
having the same problem. microphone still works but no charging. the charge light come on when connected to a computer but nothing with the wall outlet.
door
I can't hear a sound at all when I call.
door
Voeg een opmerking toe
4 Antwoorden
hey i have problem with my phone and i don;t know what to do when i true the power it said T-Mobile and it just stay like that
Was dit antwoord nuttig?
The charging port and mic is in the same part, either you didnt connect it properly, or the part broke.
I was so !#^&@@ because i took a bottle of water to school so i dont need to pay at school then my friend told me ay Immanuel your bag is leaking and i was praying that my phone would not be broke but wheni reached into my bag it had water in it it keeps coming on just saying the thing and stays like im not sure what to do now!!!! :(
Please help me...
Copy and share your contacts ,photos, such preferably to the cloud but Google Drive works just as well make sure you backup all your data send those backups off of your phone onto the cloud or something it's not internal make sure you sign out of all your accounts choose the option for Google app restore and then do a hard factory reset and that should do the trick f.y.I when you do to reset it's going to wipe all the data from your phone so it's going to be like you just opened out of the box so you're going to have to set it all up again but at the same time that's why you saved and backed up all your data and photos and things so once you get through the first tutorial real quick Google account setup real quick
Voeg je antwoord toe
Patricia Klucas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 4,737
