Ga door naar hoofdinhoud
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Vragen Bekijk alle
Vraag afgerond
red light on when phone is turned on
My phone fell into a drink for only 2 or 3 seconds before being retrieved. I have taken the phone apart, dried it, cleaned it with a tootbrush and rubbing achohol, and replaced the battery with a samsung original replacement. The red light on the top left of the S III screen, just left of the samsung name, lights up whenever i turn on the phone and remains on as long as the phone is on? The screen will also go dark when making a call from the key pad unless i activate the speakerphone function immediately after touching the call button. Do you have any suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It's possible that there is still liquid damage/corrosion on the screen.
The issue with the screen going dark is most likely the caused by a damaged proximity sensor.
Was dit antwoord nuttig?
Took the phone to a brick and mortar repair shop (UBREAKIFIX) and their assessment is obscured proximity sensor. You appear to be right on the money. Thanks.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 121
